Is this valid advice about tyre wear?
1 Feb 2005
Tyne and Wear
Just got my MOT sorted except for an advisory on front offside tyre, where the Inside shoulder is wearing, right on the corner, about a centimetre wide strip.
The mechanic doing the mot said that its been caused by how I'm parking the car by not straightening the wheels when parking and also turning too quickly when steering in and out of parking bays.
This is a new one on me.
I would have thought the wheel is towing out and book it in for alignment?
You wouldn’t get just one wheel toeing out. If one wheel was knocked out of alignment by 10 degrees, it would equalise to 5 degrees on each side when you were driving.
The left side looks okay.
I thought this sounds like he was waffling
Best to get the wheel alignment checked?
There was some very slight play in the offside front wheel but said it was so slight it wasn't worth fixing yet.
Could be tyre scrub like he says. We reverse off our drive on a hard right lock and that gives more wear on the inside of our offside front tyre. Not enough to make them illegal but I can notice it.
You shouldn't get the alignment checked or adjusted with any play in the steering joints. Any play should be corrected before checking or adjusting. It’s part of the standard checks you carry out before checking/adjusting alignment but hardly any places do that. Or check the tyre sizes and pressures. Or make sure you are on dead level ground. Strictly speaking, you are supposed to put weights in each footwell too but I’ve never done that myself.
Ah okay .. thanks for the info. I'll keep an eye on the tyre and also not use hard lock if I can
