I've recently replaced the ball valve of the storage tank in the loft as water was flowing out of the overflow pipes. Everything seems to be working fine except that when the tank is just about near full and the flow of water is down to a trickle, the feed-in pipe starts to groan and vibrate quite loudly.
However, when I lift the ball rod up to fully shut the flow of water, the vibration stops. If I let go and let it continue to fill up the vibration returns until the water level is high enough to force the valve to stop flowing.
Also, if i stop the feed via the stop cock and turn it back on again, the vibration is gone.
i'm assuming that this is water hammer from reading other similar posts and invariably the solution is a replacement of the ball valve, but this is a new one.
Any suggestions would be appreciated.
