isolater valve
18 Dec 2011
I turned the isolator valve under the sink to stop the hot water from coming out of the tap but now i have turned it back on it leaks what can i do.
take it off and fit a new one.
You don't describe it or say where it is leaking from, but I will guess that it is a ball valve and has a screwdriver slot and needs a quarter-turn from on to off.
You can buy them for 90p if you don't mind replacing them when they leak, and repairing the water damage.
Or you can save up a few extra pounds and get a Pegler. A full-bore one will give better water flow.
http://www.screwfix.com/c/heating-plumbing/brassware-valves-taps/cat3830014
