Hi there,
This is a picture of the hot water feed to the bathroom sink (I know it has a blue tab on the valve).
Copper pipe connects to the compression joint of the isolation valve. Then a small length of copper pipe connects the valve to the flexible hose to the sink tap.
There is green discolouration as you can see, which presumably is a small leak in this area. I assumed the compression joints needed tightening a bit but when I turned off the isolation valve it would NOT turn off fully AND a small squirt of water seemed to come out of the centre of valve itself. This seemed to stop when I turned the isolation valve back on again.
So, my question is this - Do isolation valves leak from within themselves and out of the tap and why does the valve not fully turn off? Or is it still likely that the compression joints either side of the valve onto the copper pipe and on the flexible tap hose need tightening?
Thank to everyone for their advice.
Mutley56
View media item 35064
Mutley56
