Isolators on radiator pipes... what should I do?
12 Oct 2009
Hertfordshire
Hi Folks,
We did have a tiny radiator (400mm wide) fitted with compression valves from existing pipes from the floor that used to server an 800mm wide radiator.
I have removed the small radiator and want to put back a new 800mm radiator as its a cold room and the old pipes looked messy.
I have a dilemma... the two copper pipes from the floor both have isolators on. What should I do?
Is there a fitting I can use to attach the TRV and lock valve onto the isolators? Or.. should I remove the isolators and a put the valves directly on the copper pipes? Problem with this is that firstly I'll have to drain the whole system to remove the isolators and the pipes from the floor seem to be quite low?
My head is saying that I should do the job properly and drin the system and removed the isolators? Do you think thats best?
Thanks for any advice...
theres a good chance they will leak when you turn them back on,drain down and remove or renew them
