Hi -
I have an oil boiler (there's no attic tank - just a small tank fitted inside the boiler unit - (I think it's a Worcester)) which was serviced and had some new parts fitted in March including a new 3 port valve and a new expansion vessel. At the time the plumber noticed my oil tank was leaking at the top and letting water in and suggested I fix it. What did I do ?? You guessed it ! Nothing
ok - forward to 2 weeks ago - boiler makes a popping sound and dies, won't restart. Get the same plumber out who tells me my oil tank is now feeding water into my boiler.
So I'm a £100 lighter - could have been worse I suppose. The central heating came on fine after pumping out the water from the tank and supply pipe.
This is when the problem started.
The central heating seems to be working ok - except:
1) The pressure is reading 4 bar
2) The hot water is freezing cold
Solution : Turn of the central heating - the pump stops, once the pressure goes down to 2.5 bar (ish) - the water gets hot.
Before I get the plumber out again - does anybody have any ideas what could be wrong? I've tried bleeding the rads but they're all fine - thought there might be air in the system.
I'm guessing it's the 3 port valve that's gone but I'm surprised seeing it was only fitted in March. Would have thought any water damage would affect the burner unit and not the valve.
Any advice appreciated.
RobH
RobH
