Jaguar Boiler problem
7 Dec 2007
Bradford
Hi
I need some real help.
My gas jaguar boiler is a pain.. and today when i came to put the hot water tap on to do some washing up my boiler would not kick up.
So i thought that it must be something wrong with the spark.. so i put central heading on and this was fine.. kicked up all ok...
so i retryed the tap and there was a little hot water, but the boiler still would not kick up to heat it, and the water went cold again.
They only thing that has changed was we put a new radiator in the bathroom and the pressure keeps dropping in it, so we have to keep filling it back up every day.. so i bled the system today, hoping it will retain it.
BG will be coming out on monday.. but there there anything i can do at all to fix it before?? i have dirty plates
thanks everyone
Sounds like a flow switch or diaphragm, what ever these have.
Nothing really that a damsel in distress would probably want to attempt :(
I can only suggest boiling a kettle for the dishes till Monday :cry: or eating out 8)
Jaguars use a differential valve which is the same as vokera maxins so a maxin service kit is what you will need
thanks everyone
You have got 3 problems.
1 Chances are the filling up has added limescale and oxygen which has damaged your diverter. You need to repair the leak first
2. once the pressure stays okay, you can safely replace or repair the diverter without having to pay for it again.
3 you need to buy more tea and coffee as it is unlikely bg will sort out all the problems in just one or two visits
lol
Ah well he can come as many times as he likes as long as he fixs it.. and seeing as i have the best cover possible it should not cost me that much.. unless its total buggered!!
its also unlikely he knows what hes talking about
i meant bengasman, not the BG guy who may or may not know depending who he is. :lol:
of course i talk ****, i'm a plumber, what do you expect? :D
many apologies, i wasnt aware of your qualifications, it makes perfect sense now :lol:
woop
BG came today.. and guess what they fixed it straight away! they replaced a DH pressure switch membrane thing.. and then put some air in the overflow.. and all my problems have been solved in one!!
woop
thanks for your help guys :D :D
