Jaguar Combi Boiler
27 Jul 2006
Newcastle upon Tyne
we have a jaguar 22kw combi boiler and the problem we have with this is that when the hot water to the bath is ran its not particulalrly hot. The water to the tap at the basin in the same room very hot, as it is downstairs.
Could it be that perhaps the feed to the bath is 22mm (I would have to remove the bath panel to confirm this)
Any ideas anyone?
Many thanks.
Hi Corgiman,
Just running it now at not too great a 'rate of knots' and its much better. It'll take about 20 mins to fill the bath mind.
Been watching the temp on the combi and its between 58-64.
Think maybe its fed from 22mm?
Defo feed from 22mm
what is the boiler doing while you are running the tap at this rate?
Hi Corgiman,
The temp drops to about 25oc and less when the tap is opened fully.
Guess you're/we are correct with the 22mm assumption.
Thanks for taking the trouble to reply.
Another job!!!
