Hi, I've just had a boiler moved by my mate (an approved gas engineer) - who's now on holiday!!! - (old Plumbcentre - Jaguar - I know they don't have good press but its been fine for the last 6 years ) The issue is when turning on from cold the boiler rapidly hit the max temp setpoint and knocks off (no fault indication though) - ie it seems that there is little in the way of circulation. I installed a cross-over within 3 m of the boiler to check oultet / return temp and this proves flow - which showed return flows. I've fully bled the system, stripped and checked the pump, yet it seems there is little active flow. The only other change was the removal of a radiator in the upper bedroom - a small unit with no thermostatic valve, therfore open to the system feed / return at all times - assuming this may have been the issue - I re-created this loop and it still didn't make a difference. I'm assuming that the minor changes in pipework may have increased head to the degree that I've got insufficient flow. The pump is integral and single speed? Add a second pump? Change the pump? Can't wait until mid Jan
