Jammed expansion bottle lid
1 Feb 2005
Tyne and Wear
Hi all,
Fiesta zetec s expansion bottle lid came apart, leaving the inner part jammed tight in the opening.
I have tried leavering it out with a screwdriver and also pliers but can't get enough grip.
Before I damage the bottle, is there any tips for loosening the thing off?
I was thinking possibly pouring hot water on it. Currently the coolant level is right on the main mark so no immediate need to get the bigger off. Any suggestions?
Get a broad screwdriver and use that as a "drift" to tap it around in the opening direction.
Nozzle
I was able to release one using slip joint pliers...that was on a C Max though.
Give us a picture if you can.
John
Drill a hole in it, screw a self tapping screw into it and use a couple of flat bladed screwdrivers to lever it out.
Take it for a run to get it hot, then try one of the above. A secondhand bottle is about £35 off flea bay so not the end of the world and probably easier in the long run if the inner is stuck.
