Jammed stop cock
10 Apr 2021
I've got a few jammed radiator stop cocks. If I pull them out by force, can I keep the stop cock and just replace the seal or must I replace the whole thing ? If I need a rubber seal, can someone advise which seal I require.
How do you mean they’re jammed, As in won’t open or open but stuck washer
Ah ok, yes, if you can get them out then a new rubber washer will do it. You may need to use a small screwdriver or pick to get the old washer out as they tend to get stuck on the seat.
