JG Speedfit pipe question.
7 Oct 2015
As a DIY'er I've decided to use JG Speedfit pipe and sundries for a plumbing project which includes both hot and potable water systems. (No Central Heating pipes involved) Looking for best prices on the internet I find many outlets only stocking the barrier pipe. I thought this was only for CH systems. Can I assume this is the only one they do now and is good for all systems. (hot, cold potable and CH)
Many thanks.....McCfuzz.
All PB/PEX barrier pipe does is stop O2 being drawn into the pipe. Most makes are fine to use on potable water, if in doubt just check it's WRAS approved.
If you are going to use JG or any other plastic, don't make the mistake of thinking 15mm plastic is equivalent to 15mm copper in terms of flow. Same for 22mm.
I read years ago how much "the restriction caused by the small diameter inserts was offset by the reduced friction of plastic", but my experience was that plastic can be the cause of poor flow.
If I had my time again when I used plastic and didn't have time to solder and check everything, I'd buy copper pipe and use plastic fittings or compression. Best of both worlds for DIYer in my humble view.
Later, you can swap connections to soldered copper if you feel like it.
Just a suggestion I'd have given myself 10 years ago.
Good luck.
