John Lewis JLWM1607 washing machine not working
I'm on it!! How likely is it there would be poor connection at fuse to cause this. Could it be anything else. Would have explain why the machine is not pushing through on even starting a spin cycle that I was testing it on.
Or...do I still need to check the belt isn't snapped?
Yes it's still worth checking the belt while you have access. You should only need to remove the lid.
The voltage may be dropping to an unacceptable level for the controls because of the burnt plug/wires
I'd also replace that socket with an unswitched metal one. Switches, especially if unused for long periods, introduce resistance (ie heat under load). The metal will help dissipate inevitable heat from new plug as washing machine is a high load device.
Sorted out that cable and put in a metal box for socket.Just took off the back of washing machine and the belt is fine. No slack of obvious degradation. Nothing else obvious in there burning away.
Could the poor connection with the fuse lead to the issues I described (which had no error code I might add) and be the route of the problem, do you think?
As a retired engineer, I would fix the obvious things first (compromised power supply) before looking for anything else.
Many faults in the machine could cause a fuse to blow or MCB to trip, ie a more binary fault.
Your burned plug & socket just looks like years of use causing heat damage. Resistance of poor plug fuse connection will have caused voltage drop to the machine when the heater element put high load on the supply.
How that would manifest itself in machine operation is anybody's guess. Fix what you see and test machine operation again.
Replaced plug and machine now all works (for now) so thanks to all who solved this for me.
I do have to ask, when I had this kitchen fitted, this was the set up with the feed pipes for the sink touching the socket. Is this legal ?
I do have to ask, when I had this kitchen fitted, this was the set up with the feed pipes for the sink touching the socket. Is this legal ?View attachment 427125
Move the back box down and put the socket back on the right way up. I would have used a metal unswitched socket tbh. (For better heat conduction).
I was told that the socket could not go on the right way as the cable of machine was prevented due to the socket being so close to shelf. Do I need a metal backbone or will the existing plastic suffice.
Plastic is fine.
