Joining chrome waste pipe to PVC
Maybe better to practice first before destroying your only bit if of concreted waste pipe :?:
you could just use a cut down one of these
and cover it with one of these
If you used a cut down one of those Fernco / flexseal things (upper picture), you could have a GAP between the pipes! So make it all as short as you can. I shld thik you could cut the rubber down to an inch or so, but more woud be better in case it got kicked.
Sorry -- too many posts arriving at once! I meant - what overlap for the heat gun solution?
I did consider using a Flexseal solution, but was concerned about its robustness if it got knocked.
Heat gun solution would about an inch, but practice first so you don't ruin your existing waste! :wink:
If it goes brown its way too hot. Keep turning slowly until both parts are cool again.
