Joining metal and concrete
11 Jan 2022
I've just got a new shed in a box set up - nearly. One side of it I can used the ground anchors supplied into the ground no problem. The other side is a problem. The metal frame is basically sitting on a low brick wall. I was going to use some fixings which required drilling into concrete, but I think if I did that the bricks would shatter. I then got looking at google and have come accross the Evo-Stick Sticks Like Sh*t Turbo Grab. Would that work or can anyone suggest any other alternatives?
Forgot to say, the bricks have a 5cm concrete top that I'd have to get through first, then they're concrete bricks underneath, not red ones.
If you're drilling downwards it can help to clean out the dust often. I've used a bit of Flexi pipe before and blown into the bottom of the hole every so often, but there may be other techniques.
