Hello. Hope everyone on here is well. It's been a little while since I've visited.
I've bought a 5kVa transformer which has aluminium windings on the primary side.
The ends of the windings are connected with standard through crimps to the incoming copper wires. These appear to be the original factory connections.
One of these joints has failed completely and the other is also showing signs of thermal damage.
I'm wondering what type of connection would be the best to prevent this from happening again?
The windings are a single solid core approximately 4.0mm² CSA.
As I understand it the problems with jointing to ali to copper is galvanic corrosion, oxidisation of the ali, and deformation of the ali core. I was wondering about wago connectors as they apply a constant pressure to the joint without crushing the conductor, and they appear to have tinned contacts which I don't think react with copper. Is this likely to work or is there a better product available for this job?
Thanks.
Thanks.
