Joist into wall
Status
Not open for further replies.
11 Mar 2022
Soon I'll be adding joists to my extension and wondered if anyone had some advice.
I have seen suggestions of a ledger board and hangers, I have also seen people suggest cutting a hole into the existing wall to rest the joist on there. The latter sounds the most structurally sound.
If I did do this, would the joist just need to go circa 100mm in, wrapped in DPM and then mortar into place?
Thank you
No need to double post. Mod.
You will get more replies if you put this in the building forum. I think you need silicon mastic to ensure the wall is air tight after placing the joist in the pocket
Blup
Status
