Joule Horizontal
Then why not nip to one of the sheds and pick up a bib tap for a couple of quid. Rig this up temporarily on a hot pipe somewhere and see what results you get?
Next time I’m at Screwfix or Toolstation il pick one up thanks.
You really should have a tundish visible at the cylinder location. Have a read of the manual pages concerning discharge arrangement and try and see how one could be provided for in the installation.
I thought it would be possible given I prepared the area exactly as required.
My problem is engaging with the plumber. He was recommended and he isn’t cheap but...
I think he is a bit of bully and fobs me off when I ask a question. I find it hard to keep on with the same questions all the time.
He Has left a mess, used the wrong size insulation on the 28mm cold feed, drilled the summer beam to fit the condensate pipe after I specifically asked him to go under it and has fixed pipes to a full size sheet of plywood that I need to move later to insulate under.
Basically he’s bit a bit of a mare and I won’t be getting him back for anything else. I’m not sure he even understood my issue.
Ohh now I’m venting lol
