Junction Box/Lighting Circuit
15 Jul 2011
Essex
I am planning to put a new light and one-way switch in my loft. Could I use a four terminal JB with all the cables wired through that, or a three terminal JB and the new switch wire coming from the ceiling rose of the new light?
Kind Regards.
TTC,
Does that mean not using a JB and simply running a spur from an existing ceiling rose??
Kind Regards
That is one of the (many) ways that you can do it.
Feed from existing ceiling rose > Switch > light
or
Feed from existing ceiling rose > light > switch
etc etc
Whatever suits you.
If I was doing it, I would take the following technique.
Its super simple, live from one cable to the common on the switch, connector block neutral and earth (separately) in the switch box (or earth lug in the box if a metal box), a new cable to the the light, Live in L1, join neutral and earth to cable 1, fit your light, job done.
