Just 5 screws per t+g 22mm chipboard board?
24 Nov 2013
Berkshire
Mike
The way I see it is that the manufacturer will specify the minimum number required so that builders put in the correct minimum number if they are on a schedule and budget.
Folk on the internet want to advise to (try to) garentee that there are no squeaks, noises or movement, and it should be remembered that internet writers have no budgetary or time constraints, so they go for a large number.
And as an example, application also makes a difference. For my bathroom with its ply floorboard that I wanted no movement from as was lying tiles on it I put down screws every 20cm. For loft where floor was a lot bigger, and less issues with movement I put in a lot lot less.
I therefore (half serious half joking) suggest you put in slightly above average at 18 screws per board.
Or buy as many packs of screws your budget can afford and divide the number screws by the number of boards so you use all the screws. https://www.screwfix.com/c/screws-n...agedredirect-_-screwsfixings-_-flooringscrews
SFK
That was one of the most informative answers I've had for a long time. Thank you very much.
