Just fitted coving, now want to paint but unsure????
14 Sep 2005
Hye
I've recently installed some coving in my parents house. Its of polystyrene type and now i'm in the position to fill and then paint the coving.
I was wondering if there was a special type of filler that i must use or can i use the adhesive to fill the joints.
Also what type of paint shall i use and do I require an undercoat?
Any help appreciated. :D :D
Shab
you can use decorators caulk to fill any gaps. Or decorators filler. Comes in mastic type tubes.
Then plain old emulsion to paint it with.
Hye benjiman
How many coats do you recommend
This decotaters filler, do i have to sand it slightly to get it smooth?
Also any tips on filling?
Thanks for the help so far
put it on as a bead like silicone and then use a wet finger to smooth it down before it goes off. You cant sand it down after and if you try youll ruin the polystyrene finish.
Hye
thanks for the advice, fully understand what you mean. Will try that and see how it goes.
Shab
