Hi Guys,
I have just got installed a vaillant eco plus boiller and the unistor cylinder which are stored in my garage and the hot water pipe 22mm goes all the way to my loft room first and then come down. This was because i had an old system in my loft conversion and had a 22mm pipe going all the way up.
Wanted to confirm on few things being new to this system:
pressure in my loft conversion to all the way down to kitchen is great but i noticed when shower upstairs in loft is being used and someone opens a tap the pressure does got bit low, not very low but you can tell another tap is open somewhere. Is this normal or should i be expecting no reduce in pressure whatsoever?
Also currently i have tap and showers which has its own cold and hot tap, when i turn on both the pressure is very high.... now if i were to purchase a thermostatic or single tap mixer, would this provide less pressure compared to separate taps for cold and hot?
