Just thinking out load - instant flooring, rot proof, breathable, strong....
  • Thread starter Thread starter JP_
  • Start date Start date
JP_
17 May 2012
Why do we go to such lengths to fix timber to other bits of timber to make floors?
If these are strong enough outside to drive cars over, why not use them on top of a the slab, then lay insulation boards on top, then screed?
OK, probably not in the building regs handbook ... but, why not do something like this, rather than mess about with all those bits of wood and nails? If using plywood instead of screed, would be easy to access for maintenance etc.
The cells measure 708mm long x 354mm wide x 150mm deep
https://www.ebay.co.uk/itm/soakaway-crates/282701056970?hash=item41d24bcbca:g:4fcAAOSw401Z6S9l
From my ground to the top of my floorboard is 34cm. Thin layer of sand to level, 15cm soakaway crates, 15cm insulation board and 3cm for flooring ...
I am probably missing something obvious.....you'd need to be able to level them near perfectly ..... as I say, just thinking out loud....
0.037 M3 crate for 18 pounds.
But 0.5m3 aggregate or hard core is less than 50 pounds plus cement for 40 max if you need it. Plus labour.
So filing with hardcore and concrete will be more economical in New construction.
Yeah, but, what about an existing floor in an old house that is rotting away with high external floor levels and lack of ventilation already?
In terms of DIY easiness, it must win.... but will it wobble, sink, etc.
Or these
https://www.roofingsuperstore.co.uk...kNQVGajSL-yS2bTmX0Un_NdvmlvQOjvYaAi5VEALw_wcB
I could just rip out all the joists, clean the area, remove plasterboard and skirting too to get rid of rot, and put these down 10-20 of these down and with a lot of adjusting and a spirit level, create a floor? Do away with the lower joists that sit close to the wall completely. Then put either floorboards or chipboard and carpet?
At £5 each for those pad things your floor will be a bit dear. Plus if your subfloor is not up to modern standards (ie is not a concrete pad 100mm or so) then they'll sink into the mud/clay quite quickly, causing you all sorts of grief.
Couple of dwarf walls, a load of 6 x 2 and some DPM and you'll have a conventional floor that you can fix whatever you like to.
That's a point - no idea what that subfloor is really like
