Karcher 520M Oil Leaking
2 Aug 2011
Cheshire
Recently, when using my Karcher 520M on flag cleaning duties, I noticed (for the first time) that oil was leaking (usual visual signs in Water on Path I was cleaning).
I suspect I have an Oil seal problem, 'BUT' am unsure ['which'] seal is the likely culprit!
Can anyone advise on likely cure, with perhaps a part No. and where I can get a replacement. (Can fix it myself if I can obtain correct part).
Any input would be appreciated
This is a very difficult one, without actually seeing the machine.
However, I would expect a seal failure between the electric motor and the drive to the pump mechanism - its actually a grease filled chamber.
So its only guesswork, and maybe someone else will know better but the grease seal number is 7.367-008.0.
I order direct from Karcher on 01295 752083.
I emphasise though it would make more sense to strip the machine to find out, as far as possible, where the leak is.
John :)
Most greatful for your valued input 'Burnerman' and for the Seal Number etc.
Would you know if there is a Specific Grease recommendation for these machines and would it be freely available? (Halfords etc?).
Hope you can help!
I only know that its available in 50ml tubes - sorry I've no idea of the grease spec.
I've just googled 520m spares and there's a pdf to look at.....it could help!
Please be aware I'm just guessing at the problem for your machine!
John :)
John :)[/quote]
Thanks again, and yes I appreciate what you say
