Karcher K2 not switching on
3 Apr 2025
Hi, karcher k2 was mot switching on, stripped on/off switch found contacts tarnished, clean and rebuilt but cannot seem to get the rocker guide in right position ad when turned on rocker does not move can't for the life of me remember if there was a spring in there holding it down, anyone got a close up of switch assembly
Done all that, obvs doesn't show enough detail to see if there is a spring holding it in place
Ha,Ha, well jfyi was testing it out of situ once back on the pump the pressure lever acts like a stop and puts rocker in correct position all working now after I also found a broken winding at motor terminal repaired now back n running cheers
