    Dismiss Notice
Karcher Pressure Washer Completely Dead
Discussion in 'Appliances' started by rocksteady, 16 Jun 2011.
  1. rocksteady
    rocksteady
    29 Dec 2008
    9
    Thanks Received:
    Glasgow
    Country:
    Karcher Pressure Washer Completely Dead, I was using it fine for about one minute then it stopped, wouldn't run again. Model K550M. Have tried another capacitor from another machine, its fine. and have pressed the switch manually with no joy, Any ideas? Thanks
  2. big-all
    big-all
    12 Jul 2004
    18,983
    Thanks Received:
    1,491
    Surrey
    Country:
    i assume you have tried it in another socket and another item in that socket to rule out the fuse and socket problems
    if your using an extension has it got an overload button
  3. Sponsored Links
  4. rocksteady
    rocksteady
    29 Dec 2008
    9
    Thanks Received:
    Glasgow
    Country:
    Thanks for your reply, yes I'm getting power to one side of the switch, I'm not quite sure how the switch should work but I'm thinking that might be the problem, after a bit of research it seems to be a common cause, or else the motor has gone?
  5. rocksteady
    rocksteady
    29 Dec 2008
    9
    Thanks Received:
    Glasgow
    Country:
    I took the microswitch apart, it showed signs of electrical arcing / burning, so hopefully this is the problem. I've ordered a new one today and will update the thread once it's fitted.
  6. DIYnot Local
    3 Sep 2019
    Country:
  7. Sponsored Links
Loading...
Share This Page
