Karndean
18 May 2008
Glasgow
Hi, I need some advice...i recently completed the karndean basic training course and since then have got a job with a kitchen fitting company installing it.
i've came across a job which the floor needed levelling i used an SLC primed the existing floor with PVA primer and layed the SLC was wondering if i could lay the karndean directly on top of it or if i would have to prime it again....if so which type of primer?
im really new to this flooring and worried that ill F*** it up!!!
Any help will be greatly appreciated!!!
Cheers
If you've used something like Balls 300 or Ardex compound (water based) you should be able to lay the Karndean with one of their adhesives with no problem. Just check its the correct adhesive for the environment in which the Karndean is going to be fitted.
Good luck!
