keep loosing coolant fluid through the tank over flow.
  • Thread starter Thread starter REY
  • Start date Start date
REY
27 May 2012
London
Hi guys,
I have a vw sharan tdi if I drive it locale its fine but if I take a motorway for about 40min to 1hour drive the temperature goes over 90d and refill coolant sign comes on. Every time I stop to check and always the coolant fluid is emptied from the tank. I don’t really know what cause this, I took the car to deferent mechanic but no one seems to know the exact problem. They changed all this parts, water pump, thermostat, rad sencer, tank and cup, radiator. There is no sign of blow head gasket as they said no babbles no creamy oil and no leak. Could anyone please help? :cry:
Many thanks
The garage should have done a coolant test to determine if any products of combustion were present in the coolant, this is usuall called the 'sniff test', and involves a re-agent changing colour from blue to red.
Wotan
As above
If you switch the interior heating off (including air con) and run the car stationary until the electric fan/fans on the engine radiator comes on. By that time, I would think you will see the water blowing out the top of the expansion bottle. The fan does come on?
Then:
Radiator blocked internally bottom pipe never get hot
Radiator blocked on the outside, visual check
Thermostat needs taking out, see if the symptoms goes away/changes
Don't keep overheating that bullet proof engine or you will be in for a hefty bill. Always ensure after an episode, its well cooled before adding new coolant
Thank you guys for the replies.
I will speak to the mechanic with your suggestions and see where it takes me.
I will update you with the progress.
Thank you again.
Sounds like what I had with my Alhambra.
It was a problem with the head gasket, which was allowing exhaust gases into the water when under pressure and forcing all the water out.
I ended up getting a second hand engine put in.
Expensive.
silly question really, but do you have either white smoke coming out of the exhaust, or is water dripping out, because your symtoms seem to point to a leaking head gasket OR a faulty water pump, but you say this has been changed
