Keeping a new section of wall square with existing wall
10 Apr 2012
Middlesex
Hi. I have a raised terrace that is 5mtrs wide and 3.5mtrs deep. I want to extend it an extra 2 1/2mtrs from the house to make it 7mtrs deep. how would I ensure to keep the brickwork square with the existing terrace walls?
thanks.
Otherwise known as pythagorus` theorem :wink: Google away
I don't quite understand the question. 5 mtrs + 2 1/2 mtrs = 7 1/2 mtrs. Or if your adding on to the 3 1/2 mtrs, then 3 1/2 mtrs + 2 1/2 mtrs = 6 mtrs. Neither measurements add up to 7 mtrs.
Whichever way your extending it, I'd think you want the new walls to be in line with the existing, not square to the existing. :wink: :wink:
Using the 3, 4, 5 method (pythag theorem) is an extremely pertinent way of testing the 'squareness' of a structure so no need for the eye rolling.
I, like Hertsdrainage am not sure what you are trying to achieve, but when we, for example, build an extension parallel to an existing structure, we cut a gauging lathe to the measurements required and butt this against the existing structure as a kind of measuring rod.
The lath will have the relevant markings paint sprayed onto it marking out the trench width etc.
The reason we do this is because the lathe is fairly rigid, it saves getting the tape out all the time (in the wet) and it needs to be done often as the digger churns up any previous marks. Lines and pegs are also used when actually setting out the brickwork.
Yes sorry :oops:
Is there a standard method for this?
