I recently purchased a mid victorian terrace property which is one of 4 houses in this build.
The party walls between me and my neighbours is only half a brick wide (i.e. stretcher bond) on both sides.
Of more concern is I have also noticed that on the neighbouring property the gable end of the terrace (external wall) is also only half a brick wide. Surely this should be at least one brick wide to keep the terrace supported?
The front and back walls of the terrace are one brick wide, but it appears all the walls which connect between these and divide up the terrace into the 4 properties are only half a brick wide.
Should i be concerned?
