Hello - We are having issues with our boiler in which the hot water works sporadically. I tried topping the pressure up with a filling loop, but it tops up at 1.0 which is quite low.
The heating works fine.
When it isn't working, the hot water will start, but will get cold rapidly. The green light on the hot water side isn't firing either when this occurs. I am assuming that it could be because of the low pressure, but the manual says that 1.0 is acceptable.
Any help would be appreciated.
Thank you!
Thank you!
