The flue pipe assembly on the inside of the boiler is leaking around the rubber connectors top and bottom. All the internal cables etc are clear of the leak and the water is collected in a jug under the boiler.
This is due to a previous leak (now fixed) when the boiler was installed - from the flue outlet connection on the top of the boiler - and the leaking condensate ran back down the outside of the flue pipe and corroded the jubilee clips around the rubber connections.
Three of the clips have been replaced but one of them (top, nearest boiler top) just doesn't seem to make the connection watertight - maybe I have overtightened or damaged the rubber, anyway a steady drip of condensate from here.
The fourth jubilee clip at the bottom of the flue pipe I got off Ok, well it disintegrated but I can't get a replacement down past the rubber seal and into position because there doesn't seem enough space and it is awkward getting access to work in that area.
So my questions are - any ideas on sealing the existing pipe connections to stop them leaking?
If I replace the whole internal flue assembly will I have the same difficulty with that bottom connection?
How much should I expect to pay to have the flue replaced by a corgi engineer.
Any help on this will be greatly appreciated.
rwb
rwb
