Hi All Again.
Brief outline.
Old Glowworm 40B Can't remember if it's Fuelsaver of Spacesaver.
Cast Iron heat exchanger. 6 radiators. Grundfoss pump.
Converted from Gravity DHW to Fully pumped.
Water nice & clean. (Dosed every 2 years with X100)
THANK YOU ALL for the previous advice about my pipework.
It is now re-plumbed with dedicated feed & expansion pipes.
So much better.
However......I have had to turn the boiler stat down as it has (for years) kettled. Water flow is very good, but it still produces air inside the boiler.
I've searched topics in this forum about de-scaling but can't seem to find an answer to this......
I presume the de-scaling chemicals are quite harsh. Am I better isolating all rads, and only running the de-scaling chemicals round the DHW heating circuit? Keep it in as long as instructed etc. Then, drain the whole system & re-fill with fresh and add Sentinel X100 again. (As is already in the system).
What brand / chemical would you suggest for this task?
Any helpful suggestions?
Ian.
EDIT......THANKS ALL AGAIN For the advice about dedicated feed / vent pipes.
You were all correct. It was the only way to do things properly![/b]
Brief outline.
So much better.
Ian.
