Hi. To save myself from calling a locksmith I can't afford right now, I thought I would try to remove the broken key that has snapped on the outside of my front door.
The door is locked and there is still a bit of the key sticking out that pliers can grab on to. However, despite spending hours trying to pull it out, the key just won't budge. I can only apply so much grip and force to pull it before the pliers slip off though. However it does seem to be stuck. The position the lock in is straight.
I've read various sites who offer suggestions but none that have helped. I don't fancy drilling the key hole in the event I make things worse.
I do have a spare key, but it won't work from the inside. It inserts in to the key hole but it won't turn. I've also tried poking the key out from the inside using wire and various sized screw drivers but the key just won't budge.
Is there anything else I can try before I call the locksmith?
