- Joined
- 10 Feb 2008
- Messages
- 4
- Reaction score
- 0
- Country
First post - can anyone help ?
I've got a relatively old Kingfisher II (R.S.50B) that I want to upgrade to a sealed system. The boiler is rated to 3 bar, so should be suitable. I know that I have to get an overheat thermostat, new control thermostat, interrupter body and lead assembly - these are listed in the installation instructions. However, the interrupter lead assembly is now obsolete ! Everything else is available. So the first question is, any suggestions for someone that might have one in stock ?
Next, I'm not completely sure how the overheat thermostat is supposed to work. Is it that the 20mV or so output from the thermocouple is re-routed through the overheat thermostat, and then back to where the thermocouple used to screw into (now filled by the interrupter). Then under an overheat condition, the connection is broken and hence the pilot light is switched off ?
Perhaps there is a different wiring assembly that would fit into the interrupter body ? Any other suggestions (apart from getting a new boiler !) ?
Cheers,
Nic
Cheers,
Nic
