Hello all
Council is here for the last day of full re-wire but there is one small problem with my kitchen eyeball downlights.
There are five downlights (roughly 20 years old) in the kitchen which I'm told are not earthed and therefore will have to be disconnected, pendant or strip light put up for testing as per council regs and then if I choose I could have them re-connect new downlights as private job. Anyone know how much this should cost please (new cable already in place)? I'm thinking I could fit the new downlights myself, that is if they leave the cables in place? Is it likely they would leave cables in place should I advise I do not want them re-connect right away or would they remove them?
Also I've just been to shop that stock same lights that I thought would have the third earth wire but it does not, only has two wires the same as my current ones. Via google learnt that if lights are doubled insulated then no earth is required so now I'm thinking perhaps my current ones are double insulated, but is there any way to find out for sure?
On the new ones in the shop had backwards D symbol like this D--E 0.5m. What does that mean please?
Anything else in general I should be checking/asking while the electricians are still here?
Thanks again.
P.S Found PDF for new downlights (mine will be the dl1003) which confirms no earth needed. As these are identical to my current ones I suspect these too are double insulated but need to be sure.
http://www.mygreenlighting.co.uk/dow...structions.pdf
Picture of how downlights are currently wired
Thanks again.
