The downlights in our living room are 'open' downlights (not fire rated), MR16s in parallel with 35w bulbs. Each fitting has its own 12v transformer.
Since some fittings are covered by insulation (single story extension) I plan to swap them out with Aurora UNIF792SN - which can be covered with insulation and use LEDs too.
The new fittings can run with a GU10 connector or with MR16 connector (no earth, transformer needed).
I originally planned to swap them with GU10's as there's more choice but upon checking the existing lighting wiring - it's only 2-core, there's no earth.
The new downlight fittings are not double-insulated either, so earth is required.
I can see my options as:
A) Have someone re-wire with 3 core to introduce earth. Fit lamps as planned with GU10 connector.
B) Keep wiring as-is.
Use new downlights with MR16 connector.
Instructions clearly say not to use earth when using MR16 connector.
See if existing transformer works with LED bulbs OK (if old style), if not replace with LED transformers.
I'm leaning towards B as I'd rather not pay for a re-wire unless I'm overlooking something and there's a really good reason why?
Finally - is it common to run the cabling to 12v downlights without earth at all?
I'm aware low voltage installation instructions often say not to use an earth - but surely for future proofing you'd want to keep earth and by-pass it from the light fittings?
Cheers,
Cheers,
