Our kitchen drain refuses to drain. This all started after we bought a used washing machine. Some guy installed it for us, and connected it to the S bend under the kitchen sink. Everything seemed fine until the washing machine started draining and the sink filled up. I took the S pipe apart and found a lot of black waste that seemed to have come out the washing machine hose. The pipes weren't at all blocked, however, and everything seemed fine. I poured some water down the pipe leading to the well pump(We live in the basement and have one of those boxes that makes a loud noise when disposing of water), and it eventually filled up, without making the well pump do it's thing, so the block\problem has to be further down in the system. The toilet and the bathroom sink works, and they're also connected to the well pump, so the problem has to be between the kitchen sink and the well pump.
What should i do here? Will a plunger do any good here, or any block clearing solutions i can pour down the pipe? Should i contact the people that installed the washing machine?
Please reply if you have a tip or suggesion, would be much appreciated!
Bård & Kelly
Bård & Kelly
