Can someone give me some guidance on which drain should be installed externally ?
I am sure the wrong drain has been fitted prior to us buying this house. We get really strong sewage smells coming from it, so I am thinking that it has either been fitted wrongly or it is the wrong type.
I am also going to dig up the path to check the actual run of the drain in case it is running directly to main drain which is why we are getting the smells.
Not entirely sure if it works on same principle as the pipes under the sink with a water trap to prevent smells, as this could possibly be a cause for future blockages ?
As a home do I need to install a fat trap ? Not that we put fat or grease down the drain, some obviously finds its way in........
