Kitchen Extractor Hood
14 Jul 2009
Aberdeenshire
Looking at fitting an extractor hood with chimney above our range cooker.
However...I'd like to utilise an already existing wall vent for the ducting, instead of breaking another hole in the wall.
This vent is approximately 2' away from where the "chimney" will hit the ceiling.
Assuming there will be internal ducting within the "chimney", will it be OK to extend and run this along the wall/ceiling and just box it in with MDF or similar, or is there chimney parts available for varying configurations...?
Dougie.
14 Mar 2006
Essex coast
The chimney is usually just a cover, internally you fit a foil flexi hose [plastic will melt] and run to outlet, depending on layout you may be able to run to existing though if on external wall I would put a new hole out from chimney.
I needed to run to ext wall in this kitchen so boxed over the top of units, you can use mdf or plasterboard the latter being cheaper and fire resistant but a little more work to make good.
14 Jul 2009
Aberdeenshire
Thanks...
The vent I speak of is on an external wall, just above the far left wall unit on your pic...
