Kitchen Extractor Location
16 Sep 2024
I'm in the midst of an extension and am looking at routing for a kitchen Extractor. Our kitchen isn't actually moving location and I'm not sure our building officer cares that the existing is simply a recirculating Extractor, unless we change it, but if we do routing is tricky to get an outside wall.
Can I vent out of a boundary wall, essentially into an open void ( open top between roofs, and front) between my neighbours and our extensions. It's a circa 125mm to 150mm gap. The alternate would be to bring it out the same but continue the duct run external to bring it to the front, or possibly have a down draught extractor and bring it under the floor and out at a low level.
For clarity, this is not a party wall/shared wall. My neighbours extension lies on the boundary, my extension is inset 125 to 150mm onto my land
Roof?
Roof could be an option, not ideal as it would lead to a mass going up from top of cupboard run, up to a vaulted ceiling then through. Could maybe be done with a super low profile flat channel but then there are also run lengths to content with
If you are only using a kitchen extractor then venting out of the side of you kitchen should be OK but you would need to use the type of external vent pipe that is fitted from the inside
Purely kitchen extraction, yes getting a cover on wouldn't be easy from the outside at all. Not impossible but there are easier alternatives
