Hi all,
It seems to be a hot topic here at the moment but I need to put in some boxes so that the electrical first fix can be done in a kitchen I'm working on.
I recall from a similar project that I had to put the cooker panel a certain distance from the hob/oven. Am I right in thinking that the oven isolator has to be at least one metre from the hob?
Thinking similarly, are there any other minimum distances for plug sickets? I'm thinking specifically about keeping them away from the sink.
Finally, for the cooker hood, is it normal to feed this via a switch spur? It seems wrong just to take a supply directly to it. Do they go in on the socket ring main or can they be taken from the lighting circuit as they're only low power?
TIA
Jever
TIA
Jever
