Kitchen flooring renovation - how low should we go?
How much of the floor should we re-do in our case above?
  • Keep it cheap & functional, laminate on top, reinforce/ply on joists to support the new units only
    Votes: 0 0.0%
  • Invest and strip floor down to joists, plywood everywhere, make nice and modern with gluedown LVT
    Votes: 1 100.0%
  • Total voters
12 Mar 2024
We are renovating our ground floor kitchen in Edwardian (1930s) house in London. No extensions/structural/notifiable (as far as we know) work planned, just new flooring and kitchen units.
Whilst pulling up the old kitchen and flooring, the builder has highlighted that the current flooring is bad and recommended that we strip it all down to joists and fit exterior grade plywood on top. The area where the sink was is definitely loose with the floorboards falling apart. Now that we can see the layers, it is original suspended timber floor, layer of tiles, some sort of old LVT tiles.
We were not anticipating so much work to the floor, hoping we can lay LVT or re-lay new laminate (I know, not ideal, but we have time and budget considerations)
Question – should we just fix joists only under the new cabinets and replace laminate, hoping it will last another 5-10 years, or invest in doing the floor properly? Our major concern is unearthing even more work and problems as we will be lifting 100-year old floorboards for the first time ever, without external advice on how to fix things properly.
Are there any building regulations that we need to be aware of prior to going ahead with replacing all the flooring (up to the joists), or other things to consider?
Being a “simple” renovation, we don’t have an architect or structural engineer on the project. Our key concerns are around any building reg requirements for updating joists/ flooring – eg is it compulsory to add insulation (replacing 100% of the floor in that room), reinforce joists, is the spacing between the original joists important, does everything need to be brought up to 2024 building standards? What are the implications down the line if we don’t when it comes to selling the house? We trust our builders will do a good job but adhering to building regulations is what is giving us anxiety.
Your help and advice will be much appreciated - we are under pressure to make a decision asap so it adds to the stress!
I'd agree with the builder.
Get it all up, then you can see what's going on, you don't want any nasty surprises after you've fitted your kitchen.
Check air bricks are present and clear of debris.
Get some timber preservative and paint your joists with it.
Insulate between the joists. (Yes more expense, use loft roll onto netting if money is that tight, but it's well worth doing.
Put down your 18mm plywood, exterior grade (it doesn't need to be 'marine grade' you are not building a boat)
Your final floor covering can then be whatever you like. If you really are on a budget you can fit the kitchen and plinths, and do the final floor covering later, but cheap laminate will do for now.
Your builder might recommend putting all new floor joists in, but make sure he's not just trying to get extra work out of you.
