    Dismiss Notice
Kitchen mixer tap - cold water flow significantly reduced
Discussion in 'Plumbing and Central Heating' started by richyt, 28 May 2011.
  1. richyt
    richyt
    28 May 2011
    Thanks Received:
    Northamptonshire
    Country:
    I have a mixer unit on the kitchen sink with one cyclindrical unit two tops on either side. The pressure has been fine for years for both hot and water but today when I was running the cold tap the flow just suddenly reduced to a trickle. Sounded as if something had just blocked the pipe.
    The hot water side is still ok and no issue with pressure. The toilets seem ok and refill. and the cold taps upstairs dont seem to have an detrioration in pressure.
    Any ideas? is there a seperate valve in the mixer tap that could have failed just for the cold element?
    Hope I put enough information and not left anything obvious out...
  2. Sponsored Links
  3. helptavner
    helptavner
    23 Apr 2011
    374
    Thanks Received:
    Derbyshire
    Country:
    new tap heads :) had the same problem in the past
    or new taps would be a good investment
  4. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
