I'm planning to replace a worn out monobloc mixer tap in our kitchen. The existing tap has 2 levers and I want to replace with similar. I fancy the Grohe range but I need advice because our system is mains fed to the cold tap and gravity fed to the hot tap - I reckon about 0.2 bar. Our existing tap emits higher pressure from the cold side, as you would expect, but it's simple to adjust the two taps to get the required temperature.
I like the Grohe Ambi but they say it needs 0.4 bar minimum, so presumably unsuitable. Can I get something similar that would work on my system, preferably a good quality item?
How much does it matter about having different pressure to the hot and cold taps? Is it necessary to fit a pressure reducer on the cold side?
Many thanks if you can clear this up for me.
