Kitchen monoblock tap remove
13 Jun 2014
Northamptonshire
Looking at removing this tap but after looking up and taking a photo of the fitting , I cannot work out how it held on.
This is mounted to the worktop and behind a belfast sink,
There is a plate under one of the flexi pipes and the white fittings are not what I was expecting.
I thought there would be one hole and the pipes screwed to the base of the tap or 2 tails joined just below the worktop.
It looks like 2 smaller holes and then joined to the flexi pipes.
Ant thoughts?
Cheers
If this is fitted to a Belfast sink, then call a plumber otherwise you would be in a world of pain trying to remove and fit a new tap.
Andy
Thanks ,
I have thought of removing the sink and probably will go down the plumber route.
I looked at mono block fittings kits and all the ones I see go through one hole.
Cheers
