    Dismiss Notice
Copper tails on a monobloc kitchen tap
Discussion in 'Plumbing and Central Heating' started by anta, 14 Mar 2010.
  1. anta
    anta
    18 Jan 2008
    76
    Thanks Received:
    Staffordshire
    Country:
    I have an old kitchen tap (~1980s at a guess) which I want to reuse on a sink in my garage. It is a single hole mixer tap and has two copper tail pipes on it. One of the pipes is very loose and I doubt it will be water tight. It turns freely about 1/2 a turn or so but then becomes stiff again.
    How do the copper tails detach from the tap? And if I remove them can I use modern 10mm screw in flexi pipes instead?
    All help appreciated.
    Cheers
    Ant
  2. Sponsored Links
  3. Nige F
    Nige F
    28 Jun 2005
    21,082
    Thanks Received:
    1,721
    Country:
    cut them off short then unscrew as normal thread- Yes you can get flexi replacements :idea:
  4. anta
    anta
    18 Jan 2008
    76
    Thanks Received:
    Staffordshire
    Country:
    Well I've done as you said and they're now undone. They were an anti-clockwise thread! Is that normal?
  5. mrgas
    mrgas
    13 Nov 2007
    3,745
    Thanks Received:
    817
    Sussex
    Country:
    If they unscrewed anticlockwise that would be totally normal.
    If they screwed in anticlockwise I doubt you will find replacements for them. Never seen left hand threads on tap tails in 30 years.
    • Thanks Thanks x 1
  6. anta
    anta
    18 Jan 2008
    76
    Thanks Received:
    Staffordshire
    Country:
    Well I double checked and they are indeed anti-clockwise threads. Anti-clockwise to tighten them, clockwise to undo.
    So does anyone sell flexible tails with anti-clockwise threads??? Or do I need a new tap?
  7. muggles
    muggles
    28 Oct 2005
    12,849
    Thanks Received:
    2,869
    Daventry
    Country:
    New taps I'm afraid, if it's a left hand thread then there's no guarantee it's a standard pitch so even if you did find new tails with left-handed threads, which is highly unlikely, the pitch may be wrong so they wouldn't screw in anyway.
  8. Sponsored Links
  9. Lincsbodger
    Lincsbodger
    15 Mar 2010
    1,302
    Thanks Received:
    Country:
    screw them back in with a big dollop of boss white?
  10. muggles
    muggles
    28 Oct 2005
    12,849
    Thanks Received:
    2,869
    Daventry
    Country:
    They've been cut off short so I expect they're beyond use
  11. anta
    anta
    18 Jan 2008
    76
    Thanks Received:
    Staffordshire
    Country:
    Ok. Thanks for the help guys. I only need the cold connection and one of the tails is not quite beyond use so I'll tighten it up with some sealant around it and see what happens. Otherwise I'll be after a new tap.
    Last question (I hope) is the hole in the drainer the same size for monobloc taps as for a single hot or cold tap? Or do I need to buy another monobloc tap?
  12. muggles
    muggles
    28 Oct 2005
    12,849
    Thanks Received:
    2,869
    Daventry
    Country:
    The hole is normally larger for monoblocs, if you got a single tap with a large base to it you might be able to cover the hole but it'll probably move around over time
  13. shapes01
    shapes01
    16 Mar 2010
    9
    Thanks Received:
    Cambridgeshire
    Country:
    "screw them back in with a big dollop of boss white?"
    Yeah and contaminate the water supply.
    If they are anti-clockwise thread, they are probably some kind of euro crap, having said that you can get spares from a brassware importer.
  14. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
