Kitchen plastering
2 Mar 2003
Yorkshire
Can a kitchen be easily skim plastered with the kitchen in place?
I'm getting a new kitchen fitted soon, and was wondering if the walls can be skimmed (between worktop and underside of wall units) after the kitchen is fitted or is it best to:
remove kitchen
Skim walls
fit new kitchen??
This would mean a lot of the wall gets unnecessarily skimmed in my opinion.
thanks
Its easier in the long run to plaster before the kitchen goes in, even though some areas might be covered with the units. But if this is not possible,it can be plastered afterwards, but you would need to take great care not to damage the units.
youngroughtcaster
Alastair,
The sockets are fine as they are, kitchen removal is like for like and the walls are pretty good so not sure what you were getting at.
thanks for the info 'youngroughcaster'
Now and again i have had to plaster parts of a kitchen after a new one has been put in. Its not the best way to do it, but if people do the job back to front you have to plaster with extra care. It's even more awkward to do if the pelmets and cornices have been put on and they've used screws "and glue" to fix them on with.
I know what you mean but you will really need to watch you dont hit the finished sides of the units/worktops etc with the trowel. Taking your time as best you can is the only way. I wouldn't start taking things to bits now the new kitchens in place. A competent plaster would do the job in a very short time, and it shouldnt be that expensive.
