I am thinking of installing one of these in the kick of my stairs in my very cold stairwell. The outside walls can get very damp but here is no room for a radiator if you want to get anything up or down the stairs.
The space behind the stairs (in the cellarhead) has flow and return pipes for the lounge radiator running right behind the stairs, and an normal elec socket. The smallest heater I can find (made by Smiths) is 700W / 2400 Btu/h on normal output and higher on boost but I don't need the stairwell to be hot - just warm enough to prevent condensation.
So...on to the questions:
1 Is this amount of heat overkill for a stairwell (there is also a radiator 180 degrees round a corner on the landing?)
2 Can you connect this kind of heater to the house thermostat or will it have it's own thermostat?
3 Will it need its own elec supply / special spur thingy?
Thanks in advance k
Thanks in advance k
