- Joined
- 10 Aug 2013
- Messages
- 3
- Reaction score
- 0
- Country
Hello. I am very amateur at this. I'm trying to fix my Kitchen sink. Basically, the water won't stop flowing at full speed and adjusting the knob seems to do nothing. As far as I can tell, hot seems fine. I can turn off the supply from the wall (there is one for hot and cold it seems), but once it's open it's a whatever. However , this flow seems to only happen on the cold side. I have a faucet similar to the one at this link:
http://www.maxidom.ru/remont_i_stro..._dlya_rakoviny/smesitel_object_dlya_rakoviny/
Sorry it's in Russian, but the picture is about what I have. I'm in Russia, so I'll be going to a store such as the one in the link to fix it.
Anyway, when I push the COLD KNOB inward, that is, towards the center, it stops, as though some gasket or hair leak is being sealed, and the faucet works as normal. If I push a little, the supply hose shakes and makes a grinding noise, and if I push hard it's as though it were working normally, but I have to hold it there otherwise it pops out. The warm doesn't have any pop or give. I tired tightening the screw but it's in all the way and I started to strip it before it would go further.
I fear I have to replace the whole faucet, which because this sink is so damn cheap and so poorly placed in (even I an amateur can tell, the hot and cold are on the wrong side, and worse) I'm not surprised about. The faucet has always moved around and was never properly tightened. But maybe I can just replace some parts and not have to buy a basin wrench? I would call a plumber but it's expensive and I'm not ever home long enough to let him in, anyway, and I don't think this is a really hard job.
So, should I get new faucet? Is there something to tighten? Do I need new supply hoses?
